1978 - 1996 Big Bronco
Help!!
Old Aug 27, 2005 | 01:31 AM
madmader's Avatar
madmader
Help!!
This has been an on-going problem, that I just can't seem to fix. When you start the truck, it idles great. But, when you go to step on the gas, it boggs down, and trys to die. If you then feather the peddle, you can keep it running, and can accelerate up to 55 MPH, but the second you hit the slightest of a hill, it will do it again. Here is the engine configuration.
400 bored .030
.508 intake & exhaust lift / 278 duration cam
flat top pistons
heads shaved .10
deck shaved .10
4 bbl Edlebrock street master intake
Holley 80508S 750CFM Carb
Stock ignition
Here is what I have done to try and resolve the issue...
New 6.5 Power valve in the carb - no help
New 4.5 Power valve in the carb - no help
New #66 jets in the carb - no help
re-timed the engine with a timing light - no help
Complete tune up with new cap, rotor, wires, & plugs (auto lites)
Now, if I take the 750 off of it, and go back to the stock 2bbl carb, it runs fine, so the problem is in the carb. How do I fix it? Every mechanic that I have talked to, says that a modified 400 (like I have mine modified) should have no problems drinking down a 750.
HELP!!!!
Old Aug 27, 2005 | 09:21 AM
scurbiedog's Avatar
scurbiedog
I'm not sure about this but just trying to help ,how about the vacume advance at the distributer maybe with all you've added it needs an ajustment?
Old Aug 27, 2005 | 01:29 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Are you using the same fuel filter on both carbs.?
Old Aug 27, 2005 | 05:45 PM
madmader's Avatar
madmader
I am doing something very stupid, and currently running NO fuel filter...
Old Aug 27, 2005 | 06:35 PM
cookie88's Avatar
cookie88
FTE Emeritus
At least that rules it out as being the problem.
Is the choke working right on the 750? What about a vacuum leak?
Zazoos
Oct 7, 2016 09:21 AM
Rusty_S
Jun 22, 2016 07:52 AM
bull jr
May 31, 2015 04:29 PM
Hodge_justin
May 5, 2008 08:54 AM
madmader
Aug 2, 2005 02:02 AM
