shocks
Old Aug 26, 2005 | 08:43 PM
fordcoop's Avatar
fordcoop
shocks
Looking for an all around not expensive shock. Had seen earlier recommendations for Monroe Gas Shocks. They are about $56 for two at Kragen. I have a little problem with the rear end sagging a little(see photos) Is there a better shock choice or another remedy for dragging the back end? Thanks. FC
Old Aug 26, 2005 | 08:44 PM
ford390gashog's Avatar
ford390gashog
56.00 for 2 thats way to much. give me a sec i will look them up.
Old Aug 26, 2005 | 08:45 PM
ford390gashog
in order to look them up what year is it? 2wd or 4x4 and is it f100 250 350
Old Aug 26, 2005 | 08:47 PM
ford390gashog
Monroe 20708
Shock Absorber: Gas-Charged
15.99 www.kragen.com
Old Aug 26, 2005 | 08:51 PM
fordcoop's Avatar
fordcoop
1965 F100 2 wheel drive, that was the price for the lower monroe also at the store. Is that heavy duty enough?
Old Aug 26, 2005 | 09:35 PM
ford390gashog
yes they are stock shocks i have them on my 75 they work good.
Old Aug 27, 2005 | 04:30 PM
nealjpage's Avatar
nealjpage
If your suspension is sagging, shocks aren't going to help out that much. Might want to throw a helper spring in there or put some blocks under the leafs.
Old Aug 29, 2005 | 12:08 PM
bertha66's Avatar
bertha66
Yes, I agree, shocks will not help with the sag. Getting your springs recurved or replaced and then bew shocks. The shocks damppen the spring recoil and do not hold up the suspension.
Old Sep 10, 2005 | 09:38 PM
fordcoop's Avatar
fordcoop
air shocks
I posted awhile back asking about shocks. I finally had some time today and crawled under my 65 f100 and what I have are really old air shocks in the rear. I tried to pump them up and got just a little lift and it seemed I had the compressor going for a while. Since I can't read the psi recommended, is there a middle of the road psi I should try for? Or should I assume these are shot because they don't seem to be inflating. thanks for the help, the beast is running great besides this.
Old Sep 11, 2005 | 08:16 AM
mikecarson's Avatar
mikecarson
They're shot. Airshocks don't hold a large volume.
