Ford Truck Enthusiasts Forums
-   1961 - 1966 F-100 & Larger F-Series Trucks (https://www.ford-trucks.com/forums/forum40/)
-   -   shocks (https://www.ford-trucks.com/forums/406057-shocks.html)
fordcoop 08-26-2005 08:43 PM
shocks
Looking for an all around not expensive shock. Had seen earlier recommendations for Monroe Gas Shocks. They are about $56 for two at Kragen. I have a little problem with the rear end sagging a little(see photos) Is there a better shock choice or another remedy for dragging the back end? Thanks. FC
ford390gashog 08-26-2005 08:44 PM
56.00 for 2 thats way to much. give me a sec i will look them up.
ford390gashog 08-26-2005 08:45 PM
in order to look them up what year is it? 2wd or 4x4 and is it f100 250 350
ford390gashog 08-26-2005 08:47 PM
Monroe 20708
Shock Absorber: Gas-Charged
15.99 www.kragen.com
fordcoop 08-26-2005 08:51 PM
1965 F100 2 wheel drive, that was the price for the lower monroe also at the store. Is that heavy duty enough?
ford390gashog 08-26-2005 09:35 PM
yes they are stock shocks i have them on my 75 they work good.
nealjpage 08-27-2005 04:30 PM
If your suspension is sagging, shocks aren't going to help out that much. Might want to throw a helper spring in there or put some blocks under the leafs.
bertha66 08-29-2005 12:08 PM
Yes, I agree, shocks will not help with the sag. Getting your springs recurved or replaced and then bew shocks. The shocks damppen the spring recoil and do not hold up the suspension.
fordcoop 09-10-2005 09:38 PM
air shocks
I posted awhile back asking about shocks. I finally had some time today and crawled under my 65 f100 and what I have are really old air shocks in the rear. I tried to pump them up and got just a little lift and it seemed I had the compressor going for a while. Since I can't read the psi recommended, is there a middle of the road psi I should try for? Or should I assume these are shot because they don't seem to be inflating. thanks for the help, the beast is running great besides this.
mikecarson 09-11-2005 08:16 AM
They're shot. Airshocks don't hold a large volume.
