2000 Ford Excursion Limited V10
Old Aug 26, 2005 | 09:54 AM
BAJI26's Avatar
BAJI26
Hi! I have an Excursion limited v10 gas, when I bought it about a year ago the mpg was 11.9 now it is 11.4 almost every 2 months it goes down a decimal.
I changed the plugs, air filter, oil and checked the tire pressure, I'm wondering if it is the oxygen sensor (don't know its location)!
1. What is the mpg suppose to be?
2. What would cause this to happen?
Old Aug 26, 2005 | 12:16 PM
bigexpo's Avatar
bigexpo
i dont know really but i would have to say higher than 11 maybe 12 or 13 i have a 5.4 and im gettin about 12 or 13 adn it sucks i just cant imagine havin 2 more cylinders to put gas into id have to get a 3rd job to pay for that, but i think somethings goin on or maybe your driving style is changing or the weather just a guess.
Old Aug 26, 2005 | 01:02 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Take a moment to read the Guidelines, it will help you to navigate through and understand this site.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Aug 26, 2005 | 02:27 PM
Big Rig's Avatar
Big Rig
How many miles are on it? What type of driving do you do? Hwy or City?
What are your tire pressures at? I keep mine at 45 in ft and 55 in rears, I get around 12.7 both city and hwy. I just use the overhead computer. I notice when my wife drives it, the gas seems to go quicker. She likes to be a jack rabbit off the start all of the time and she can never keep a steady speed. I swear...she is going to wear out the torque converter.
Do you get gas at the same station? I try to use only Chevron 87 octane if possible.
Have you kept up on the other maint. such as fuel filters, tranny flushes etc?
And Again Welcome to the site..
Big Rig
Old Aug 26, 2005 | 02:48 PM
BAJI26's Avatar
BAJI26
Big Rig
Well I haven't done a tranny flush or fuel filter change yet, that's coming up really soon, use to only go to Amoco aka BP but I now share wid shell.
I take my time and gradually accelerate and gradually stop I live in the kinda city, its not alot of stop and go traffic, I hardly drive that often and when I do I don't travel above 10 miles.
I have about 96,000 on it don't drive hard no loads or pulling anything.
Could it be the OXYGEN SENSOR ??Where is it located?? Which Kinda gas works best with this engine type??
Old Aug 26, 2005 | 06:48 PM
BAJI26's Avatar
BAJI26
Anymore Ideas or Suggestions???
Old Aug 26, 2005 | 09:52 PM
XNAZ's Avatar
XNAZ
I wouldn't guess an oxygen sensor yet. I only have 2000 miles on my V10 but am averaging 12.2 combined highway/city driving wth mostly highway. This tank is going to be much less (guessing 11.0 right now) with mostly city. Don't worry about .5 mpg. It's the big jumps that will get you.
Old Aug 28, 2005 | 03:53 PM
BAJI26's Avatar
BAJI26
Anyone never got this problem that can lead me in the right direction???
Old Aug 28, 2005 | 03:57 PM
ford390gashog's Avatar
ford390gashog
heres a thought did you change to a thicker oil?
Old Aug 28, 2005 | 07:57 PM
V10_X's Avatar
V10_X
It could be the gas you use. The gas companies reformulate the gas every season. My guess is you are seeing the slight change due to the reformulation. Just a guess though. Could be trash in your fuel lines freakin' with the injectors too. That can account for small changes in fuel mileage..
I use regular old 87 octane in my 2000 V-10. I have 61k miles and I get 12.5 around town and about 15 on the highway. It goes down to about 11 around town and about 14 highway if I use high octane 93.....
BTW, I just switched to 10w-30 from 5w-30 and I have not seen any change in my mileage. My motor runs a whole lot smoother too.
Hope this helps,
Jeff
Old Aug 28, 2005 | 08:07 PM
Rev Den's Avatar
Rev Den
You cannot calculate milage to any decimal points just by getting gas. Different pumps will shut off at different back-pressures, do not worry about any thing under a mile a gallon, I would not even worry until 2 mpg difference.
My V-10 gets about 10 in the city.
Rev
Old Aug 30, 2005 | 08:47 AM
BAJI26's Avatar
BAJI26
do you mean changing my gas to a different grade?? Or to a different brand?
Old Aug 30, 2005 | 12:20 PM
V10_X's Avatar
V10_X
I would use plain ole' 87 octane. The brand is up to you, just watch out for the ethanol blended types....the major companies like exxon, bp, citgo, shell, to my knowledge dont use any blends.....just my 2 cents.....
Old Aug 30, 2005 | 01:37 PM
BAJI26's Avatar
BAJI26
That is what I use, BP 87.
Old Sep 15, 2005 | 04:52 PM
Rather be sledding's Avatar
Rather be sledding
When fuel went over the $3 mark I considered using ethanol but avoided it in the end. I have always been told that the ethanol is cheaper but you get worse gas mileage and in the end costs you more. Does anyone have any experience with ethanol? I was told by a mechanic that he has heard that sometimes the larger engines do better with the ethanol but its a case by case deal and to try it myself and see. I have a 2000 Limited with a V10. Thanks
