No spark
Old Aug 26, 2005 | 05:53 AM
1950ford's Avatar
1950ford
No spark
I have a 1950 straight six pickup I've owned for 15 years. I only drive it during the summer. It died on I-75 the other day. No warning. Just died. I first thought it was out of gas because my gas gauge doesn't work. Upon further examination I found it had no spark at the points. So I took this opportunity to do a complete tune up. I replaced the points, condensor, plugs, rotor, cap and coil. Still nothing.Then I noticed a wire was arcing inside the distributor. I took out the distributor and repaired the wire. Put it back together, fired it up, nothing. No power to the points. The battery is good. I've checked everything I could think of. The only thing left could be a broken wire. The summer is winding down and my truck is parked in the garage. I would appreciate any help on this seemingly simple issue.
Thanks
Old Aug 26, 2005 | 06:16 AM
Christopher2's Avatar
Christopher2
Veteran: Navy
Did you check the voltage at the coil it should be 6 volts?
Old Aug 26, 2005 | 06:22 AM
ford390gashog's Avatar
ford390gashog
check the points,condensor and coil voltage thats all that could be wrong
Old Aug 26, 2005 | 06:58 AM
fordman102's Avatar
fordman102
I've got new condensors that were bad coming out of the box.
Old Aug 26, 2005 | 07:15 AM
redlightning's Avatar
redlightning
Useing a test light with the key on ,on the positive side of the coil it should light up.While cranking on the negitive side the light should flash on and off.If both checks ok then the coil is bad.
I use a led test light.
A bad coil and condensor will feel like running out of fuel also.
Old Aug 26, 2005 | 08:35 AM
1950ford's Avatar
1950ford
Thanks for the advice. This just hit me. The truck has been converted to 12 volts. I purchased tune up parts for a 1950 pickup (6 volt) system. Will this make a difference?
Old Aug 26, 2005 | 08:39 AM
ALBUQ F-1's Avatar
ALBUQ F-1
The condenser would be different, but I wouldn't expect it to make it not run. Trace your wires all the way back to the ignition switch. Are you using a ballast resistor? It may well have burned out. Did you switch to a 12v coil?
Old Aug 26, 2005 | 08:55 AM
1950ford's Avatar
1950ford
I am using a ballast resistor and the coil i just installed is a 12 volt coil.
