e4od wrong gear start
Old Aug 25, 2005 | 10:10 PM
larry p's Avatar
larry p
i have a 91 f-150, the only problem i had with it was that the tranny used to jump out of gear when driving,and hard shifts. i installed a new mlps switch, and beleive i adjusted it correctly, starts in park and netural, and the back up lights work in reverse, and it dosent jump out of gear. when i installed the switch i did the wire change on at a time, also i never removed the cap holding the wire together. i used an aftermarket switch ( standard auto parts) and of course the plug was differant. the problem is now the truck seems to be starting of in high gear, i really have to press hard on the gas to get her to move, if i shift into first or second its fine. i can adjust the mlps switch from one end to the other and it still respones the same. i was wondering that if i didnt cross the wires maybe i reversed the whole plug when i installed the wires in the plug? i am trying to find a wiring diagram of the switch itself, i did find a diagram of a 91 f-150 but it only showed 6 pins being used, my plug has eight wires going to the switch. sounds crazy but not crazy as me lying on my back in a stone driveway
pulling my hair out.......any help
thanks larry
tezm
Sep 25, 2014 05:26 PM
Adam 442
May 15, 2014 11:31 AM
Greg5OH
Jun 11, 2012 12:56 PM
jeffery7614
Oct 2, 2006 12:31 AM
92 Red F150
Mar 19, 2004 09:41 AM
