Gas Smell
Old Aug 29, 2005 | 10:02 PM
Mil1ion's Avatar
Mil1ion
When you smell this gasoline odour, undo the gas cap to see of it releases pressure from the tank (s)
Old Aug 30, 2005 | 11:02 AM
1975Ford's Avatar
1975Ford
Fuel line leak checks.
With the engine running, from under the truck, check to see if the leak is not from the fuel pump or fuel hose.
Also check the fuel hoses and carburator near the carburator.
Check for fuel leaks at the accelerator pump on the carburator.
Check the fuel filter and hoses at this area also.
Check the rubber fuel line at the tank.
Check the rubber hose at the at the filler tube for leaks.
Check the fuel tank for pin holes or leaks.
Finally, follow the fuel line from the fuel tank to the engine compartment.
Old Sep 22, 2005 | 09:52 PM
nmaranto's Avatar
nmaranto
gas leak
I had a similar problem on my 77. Smelled gas, nothing on floor. Was a bad power valve on the carb. Gas was leaking down and evaporating on the intake manifold. Carb kit solved it.
Old Sep 24, 2005 | 08:07 PM
Mr. Green's Avatar
Mr. Green
I am going through this situation now too. I could smell the fuel from my 73 F250 from about 20 yards away- Nothing obvious in the engine compartment. No puddles under the truck. When I looked underneath at the tank, it seems like the area around the sending unit was leaking. Take a look at the top of your tank- this may be happening to you too.
Quick question for everyone- Would a fuel leak be enough to lower fuel pressure enough to keep the motor from running? Since I discovered the leaky fuel system, the truck doesn't start very easily (it usually starts on the first turn of the key), and it wants to die unless I give it extra throttle.
Bear in mind I drove it over 800 miles towing a car/trailer with no problems. When I got to my destination, the truck gave up. Lucky, I guess.
Old Sep 25, 2005 | 03:03 PM
snyiper's Avatar
snyiper
I wouldnt think so unless the leak is a part of a faulty carb. I guess if it was sucking air in the fuel line it would do that as well but I would think that would show up as a obvious leak.
Glenn
Old Sep 25, 2005 | 03:55 PM
Torque1st's Avatar
Torque1st
Posting Legend
A cracked rubber line can act like a one way valve that allows air to flow one way but will not show a big fuel leak the other way. Usually there is some seepage tho.
Old Sep 26, 2005 | 07:58 PM
fasthauler's Avatar
fasthauler
I put up with the gas smell on my 77 F250 for years. I finally got under the thing and replaced the vapor line to the tank. No more fuel smell. It took about 15 minutes to fix some thing that I put up with for years.
Old Oct 1, 2005 | 08:58 PM
79pos's Avatar
79pos
Maybe the seal around the sending unit has gone bad and is leting the smell out. Maybe even gas on a full tank. Look along the frame near the gas tank.
Richard
Old Oct 2, 2005 | 02:50 PM
rmalottwtes30's Avatar
rmalottwtes30
My 76 does the same thing, I know what it is though, I changed my tank and the new tank didnt have a place for the canister, when I run it and pull the cap off there is a bit of pressure. I guess when I get some spare cash I should get a new tank with the place for the canister.
