Sponsored by: Auxito
p0405 code.
Old Aug 24, 2005 | 09:44 PM
rG737's Avatar
rG737
p0405 code.
just got the Check engine light and had it scanned at Autozone. Showing a P0405 code. Truck has been running fine and continues to run fine. Any ideas what to check?
Old Aug 26, 2005 | 08:14 AM
rG737's Avatar
rG737
anyone got ANY ideas on this?
Old Aug 26, 2005 | 11:45 PM
Racerguy's Avatar
Racerguy
A P0405 can be a real pain to fix.
The common problems are broken wiring to the canister purge solenoid above and behind the rear axle, a bad canister purge solenoid or a plugged canister.
Old Aug 30, 2007 | 03:50 PM
mdpitt's Avatar
mdpitt
Lightbulb P0405
Had the same situation, dealer replaced Pressure line $10 to DPFE sensor, check your hoses to the DPSE they may be cracked or diconnected. Some other threads show pictures of the DPFE sensor, this may help
Old Aug 30, 2007 | 08:53 PM
rG737's Avatar
rG737
Well, since that was over 2 years ago, I nearly forgot about it until now... The DPFE sensor was the culprit. Replaced it and problem went away.
Old Sep 2, 2007 | 06:06 PM
jpd1945's Avatar
jpd1945
just took mine to the stealers, p0405 code replaced dpfe $296.43 seattle
Old Sep 9, 2007 | 03:38 PM
firefighter1416's Avatar
firefighter1416
Racer guy is right, this can be a pain infact i am still fighting it. I have a 2000 F 150 4x4. I have noticed no problems with it the way it is. I did have a broken wire going to the vent solonoid. What i have ended up doing is just pulling the check engine light out. Farmers fix i don't recomend that to anyone though.
Old Sep 9, 2007 | 06:05 PM
Wilber15's Avatar
Wilber15
I don't remember what this code is, but from the post i'm guessing insufficient exhaust flow in the egr? If you have the ability to do a key on engine running self test, it makes this easy. disconnect the vacuum hose to the egr and hook a vacuum pump up to it. run the self test and watch for a vacuum to be sucked on the pump. if that happens, the solenoid is working. hook the pump to the egr with the engine running and try to open it. if it opens and the engine begins to bog/misfire, then you need a new dpfe sensor.
Afreis
Oct 29, 2015 06:50 PM
wiwillis1980
Jun 24, 2014 11:02 PM
gearloose1
Oct 27, 2009 08:59 PM
