Modular V10 (6.8l)
V10 power loss
Old Aug 24, 2005 | 08:33 AM
acadia81's Avatar
acadia81
V10 power loss
I have a '99 E350 V10 Super Duty Ext Club Wagon with 140K. It's been sitting for a few months and now barely runs. Ran fine before. Before I parked it the van would misfire badly in wet weather. I have replaced several coils over time. I must admit I have never changed the plugs. I have checked all the electrical connectors I could find. It doesn't show any codes.
It starts and idles just fine. Driving down the road and several things happen.
First it feels like a bad coil (I have experiance with this), then it seems like the trans holds 1st and 2nd gear a very long time. Then the engine starts kicking and bucking badly. When I come to a stop the truck idles fine.
I ran the truck with a scanner hooked up; no codes but I noticed when the engine started missing the timing when nuts. Under throttle the timing severely retarded, lift off and the timing was normal. I don't know if the timing is reacting to another problem or the timing is the problem.
Where is the timing sensor? Any ideas? Thanks for the help.
Old Aug 24, 2005 | 08:55 AM
BFR250SD's Avatar
BFR250SD
Almost sounds like the TPS might be having issues. Either that or the computer is getting funny signals from it. I say this because of the tranny is shifting weird too.
Old Aug 24, 2005 | 12:14 PM
NoMo's Avatar
NoMo
After a few months, I'd check the fuel for any issues. Maybe it has water or has turned to 'varnish'. A fresh filter is a cheap & easy place to start.
Old Aug 24, 2005 | 08:35 PM
BFR250SD's Avatar
BFR250SD
That one hit me as I was sleeping last night. Also check the fuel filter, air filter ect.
zephyrprime
Modular V8 (4.6L, 5.4L)
Dec 21, 2016 11:20 AM
rhamm150
Modular V10 (6.8l)
20
Sep 16, 2016 08:04 AM
chiefsfootball
13
Jun 27, 2016 11:39 AM
Hogtrapper
Jan 23, 2016 02:13 PM
B.Eddy
Feb 13, 2014 09:24 PM
