hi to all. i'd like to ask something about stalling on an 86 F150. it's for a friend who has no idea about this problem. and she have some difficulties in trying to purchase some body parts for this 86. any suggestions will be much appreciated..
Welcome to Ford Truck Enthusiasts. We are glad you chose to visit our site. In order to make it easier to navigate please read the following.
Please view the main forum page to find the best forum to ask any Technical questions
Also, below some of the titles of forums there is text that explains what the forum is either for or what shouldn't be posted in it.
Then ,Inside certain forum's there could be a Read First: thread or threads attached to the top.
Please read these threads before posting.
In Addition to the Tech Forums all user's can make their relationship closer to others by visiting & joining the State/Province Chapter that relates to their location.A complete list of Chapter's is located on the main forum page, near the bottom.
Once again...Welcome to the FTE Family
If you have mistakenly made a post you have 60 minutes to edit it.
If the 60 minutes has passed,you may contact the moderator of the forum to ask that the thread be moved to the proper forum.
may be a faulty car, or not enough fuel reaching into the carb. You should also check for leaks. There are lots of vendors selling 86. you can try Ford Parts Online
hey guys. well, we managed then to take it to a repair service .
it's more about of the choke mechanism of the car says the mechanic. even I don't know what that means.
Let me clarify. F-150 5.0 was EFI or carbed in 86. Most of the trucks in 86 with the 5.0 were EFI. The rest were carbed that year.
460 was not an option in an 86 f-150.
He wasn't real clear in his first post with the specifics of the truck.
86 is fuel injected.
Pull Codes
Need more details about the truck and the problem. When does it happen
Ok now I have been confused, my 86 has a carb, can something be fuel injected and have a carb? (Scratching head wondering if she is just not awake and making the neural connections this morning)
Ok more clear now...as for the choke system, I had similar problems with mine, and still do. My mechanic says that I should get either a rebuilt carb or new one...and then we should be able to get the choke situation sorted out. If I recall correctly it is a vacum operated choke...I think, maybe, perhaps?
'86 was the first year Fuel Injection was offered as an option. You could get either carb'ed or injected on the F-150's. I ordered mine with EFI in '86. ($300 option if I remember correctly)
Reamer
