400 stroker update
Old Aug 23, 2005 | 10:40 PM
TMI's Avatar
TMI
400 stroker update
Here's a short block so far, Wednesday the heads should go on.
Old Aug 23, 2005 | 11:00 PM
73XAFalcon's Avatar
73XAFalcon
If you don't mind, are those Oliver rods? Who's crank? It looks like you drilled a good bit of steel out of it to balance it.....looks like mine! My Oliver rods and Ross pistons are really light and the motor now likes to rev. Bet this thing is gonna spin nicely. What is the final ci? 434?
Old Aug 24, 2005 | 09:00 PM
TMI's Avatar
TMI
The crankshaft is an Eagle crank, rods are also an import. CI is 434. This crankshaft was suppose to be in a 351W, but it is better in the 400 block. We can use a nice long COn rod, where the 351W with the short deck requires a short rod. Rod to stroke ratio in a 351W is horrible.
I did not know that Oliver made "H" beam rods.
Old Aug 24, 2005 | 10:10 PM
GreenSubmarine's Avatar
GreenSubmarine
Wow, Tim! It's looking good so far. Are those your KB pistons? What CR did you opt for? I know you're busy, but hurry up and get that thing on the dyno - we're anxious.
Old Aug 24, 2005 | 10:45 PM
TMI's Avatar
TMI
These pistons are machined for us by KB. We also have forged pistons coming very soon for the 400 crankshaft. They are a flat top, and we machine a dish if lower compression is desired.
Old Aug 28, 2005 | 01:36 AM
kopfenjager's Avatar
kopfenjager
Hurry up and work the bugs out, but take your time to do it right! I'm already saving money for my stroker kit from you Tim. What due you think about a .060 overbore to get 440ci? Just saying its a 440 Cleveland sounds to cool. I guese it would depend on the block? I'm thinking of about 10-1 comp and a intake closing angle to run 92 unleaded with iron heads. Screw gas mileage and high fuel prices, the money I save by not buying new truck with a crappy IFS more than compensates, and more fun to boot. I can't wait to see what that thing does on the dyno! keep up the good work. Thanx.
