Help
Old Aug 20, 2005 | 11:23 PM
351cbuilder's Avatar
351cbuilder
Question Help
I am working on building a 351C and am having a hard time figuring out if it is supposed to have a single piece fuel pump eccentric or the two piece. Would anybody out there have any info for me?
Thanks
Bill
Old Aug 20, 2005 | 11:38 PM
kopfenjager's Avatar
kopfenjager
I don't know about the Clevelands but on a 400, early years had one piece, and later years had two piece. they Changed because of a cost for production thing. It doesn't matter wich you use, they both work the same.
Old Aug 21, 2005 | 03:05 PM
351cbuilder
Smile
I need to add to my original post. The pin that drives the fuel pump eccentric on the cam that I have is not long enough to drive the eccentric. The two piece eccentric is not made by Ford anymore and I have not been able to find one in my area. Is there different cams for the earlier engines, what is the difference?
Thanks
Bill
Old Aug 21, 2005 | 07:24 PM
grclark351's Avatar
grclark351
doesn't the eccentric have a tab that fits into a hole in the cam sprocket?
Old Aug 21, 2005 | 11:25 PM
351cbuilder
The eccentric that I have does not have a tab. Is it supposed to? I know that the two piece one has a tab.
Old Aug 22, 2005 | 06:58 AM
Colo79Ford's Avatar
Colo79Ford
Thought of buying and plumbing in an electric pump...and using a block off plate for where the stock fuel pump goes?
Old Aug 22, 2005 | 09:11 PM
kopfenjager
Some engines don't use a tab, just a bolt. If the bolt backs off the engine stops running, and you know you have a problem.
Old Aug 22, 2005 | 10:34 PM
351cbuilder
Thanks Colo79Ford for that idea, I believe thats the way I will go.
Old Aug 22, 2005 | 10:58 PM
TMI's Avatar
TMI
http://www.tmeyerinc.com/cartodds&ends.htm
2 piece and 1 piece are available
Old Aug 28, 2005 | 01:52 AM
kopfenjager
Just a quick question does the second piece ecentric go on from the engine side or the front cover side? (or does it matter)if it goes between the cam gear and the inner ecentric it can't rotate. If it goes on the front, then it will rub on the front cover (I don't think that would cause a problem) Guese what way I put mine on. Thanx.
