Offroad & 4x4
Broken U joints
Old Aug 23, 2005 | 10:14 PM
Nohaj1's Avatar
Nohaj1
Broken U joints
I know this isnt necessarily an offroading question, but I figured who would know more about breaking parts and how to keep parts from breaking then you guys. I have a 69 F250 ranger with 35 inch BFG all terrains, a 351M motor, an NP435 tranny, and a divorced Dana Tcase. Yesterday I tore up my third universal at the yoke on the Tcase where the driveshaft from the tranny hooks up. Each time it happened the same way it either blew part or the whole way out of one side of the joint at the U bolt, and each time this happened it has been the same yoke. The first time I was just doing normal driving, the second time was after a few hours of wheeling and the third time was on the highway. I also have been having issues with the Tcase popping into neutral while im driving. Does anyone have any input on what may be causing this. Sorry for the long post.
Thanks
Old Aug 23, 2005 | 10:27 PM
fishmanndotcom's Avatar
fishmanndotcom
well you can tighten up your shifter a lil bit by gettin under the truck and puttin your hand on top where the shift rails go into the case. you should feel a round indention and a hex head inside the indention. if these bolts are loose you can tighten them up and it tightens up the shift a lil bit.
now the ujoint thing i'm not really sure about. you apparently have a divocred t-case with an intermediate shaft. have you tried installing new joints and then sliding the t-case forward a lil bit to keep the joint pushed into the yoke? or is it a slip shaft design? where are you breaking the joints? are you splitting the cross in half? shattering the caps? ever lose a yoke?
-cutts-
Old Aug 23, 2005 | 10:52 PM
Nohaj1's Avatar
Nohaj1
Thanks for the tip on the adjusting the Tcase Ill give that a try.
The driveshaft is a slip shaft. The damage to the universals has been the same each time the end caps have been broken up and underneath the universal is worn off almost to nothing but only on one of the four points.
Old Aug 24, 2005 | 01:17 AM
RubberDuck's Avatar
RubberDuck
I'm going to say there is a flaw in the yoke. that's too many times. Have you ever changed the tcase yoke? that's where I would start.
RubberDuck
Old Aug 24, 2005 | 02:03 PM
hoxiii's Avatar
hoxiii
I'm going to agree with the yoke having a good chance of being fubar. Either that or when you're installing the U-bolts over the caps you're cranking them down WAY too tight and distorting the caps causing them to wear very quickly. The nuts are only supposed to be tightened down to around 15 foot pounds. much more than that and you can run into issues.
Justin
Old Aug 24, 2005 | 02:13 PM
proeliator's Avatar
proeliator
Thats a VERY common mistake folks made. Make sure your yokes are in good shape, get quality spicer u-joints, and watch your pressure on the u-bolts. I never have problems with my intermediate shaft u-joints and neither should you...should be a piece of cake to get it straightened out.
Old Aug 25, 2005 | 09:22 PM
mustange70's Avatar
mustange70
Yeah i think that the yoke got damaged the first time and led to your next 2 blown u-joints.
Old Aug 26, 2005 | 01:51 AM
Hypoid's Avatar
Hypoid
It's all good! But, the imbalance associated with a worn slip yoke should be noticeable. Does the truck shake and rattle a lot anyway?
Old Aug 26, 2005 | 01:43 PM
rebocardo's Avatar
rebocardo
to add to hwat has been said.
Changing your driveshaft angle AND length when using a slip joint driveshaft is not good and can lead to UJ failure. Since you are running 35s, I would -assume- you had to put in a lift kit though if you just added 35s, that would be enough of a change on the angle and length. Your slip joint may not be engaging enough of the spline to avoid slop.
re:torque
If you tighten the straps too much you can deform the cap and prevent the needle bearings from working properly. Though the strap usually breaks if it is 1/4 thread. As mentioned I would think maybe the first failure deformed the yoke and has lead to #2 and #3. I would take the driveshaft, put it on a flat surface, put a straight edge on top of it, and measure to see if it was warped on any of the four sides. You might need the complete slip yoke for this.
