Fueling Problem
Old Aug 23, 2005 | 09:31 PM
PICCALO358's Avatar
PICCALO358
Fueling Problem
1980 F100 inline 300-6:
Refueling gas tank is very slow,is this a venting problem? Is this just a hose out of top tank? Thanks---
Old Aug 23, 2005 | 09:43 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
There should be a smaller plastic "ribbed" hose inside your filler neck to vent the tank when fueling.
Sounds like it either has a hole in it, is crushed or came off the top of the filler lead restrictor, allowing gas to enter the vent hose, thereby not letting air to escape the tank.
Have you ever tried putting gas into your saw, or lawn mower without opening the vent cap, on the container?
Hope this helps.
Old Aug 29, 2005 | 08:25 AM
PICCALO358's Avatar
PICCALO358
Thanks for the help, but I can not locate the vent line,can anybody tell me where it is?
Old Aug 29, 2005 | 01:22 PM
Lee Lichterman's Avatar
Lee Lichterman
It should run from the tank to the little notch and hole in the top of the filler tube where the gas cap goes. You can't see it unless you have the filler tube disconnected since it is inside the filler tube.
What you are looking for is the little black tube sticking out in this picture...
http://www.marketswing.com/Temporary...0placement.jpg
Good Luck,
Lee
Old Aug 29, 2005 | 01:40 PM
PICCALO358's Avatar
PICCALO358
A picture is worth a thousand words! Thanks I will check it out.
Old Aug 29, 2005 | 06:34 PM
PICCALO358's Avatar
PICCALO358
Thanks everyone, vent had slipped down from filler neck,fuel goes in with no problem and even holds more fuel, now I need to figure how to pay for all that gas!
