What to Look for?
Old Aug 23, 2005 | 02:03 PM
80`F-150's Avatar
80`F-150
What to Look for?
I`m looking at buying a 1990 F-150 4x4 300-6 4 spd.and was wondering what the most common problems are on thins trucks? what to look for? and such
thanks for you help
Old Aug 23, 2005 | 09:52 PM
Popa Tim's Avatar
Popa Tim
the I6 is a great motor, Lots of torque! Good for towing, not racing.
4sp.. is that manual or auto. I'll assume auto and they the E4OD for that year was problematic (trans code E on the drivers door jam tag)
Check to make sure all the bulb checks come on when you turn the key on. You should see the Check engine, OD, ABS, Antilock Brakes, and Airbag/sealtbelt lights all come on.
Crawl under and check the rear suspension for rust issues. Check springs, shackles, mounts, brake line, E-brake cables, gas tank leaks, gas tank straps...
If it has dual tanks, switch between them to make sure they both work and that one does not fill theother. There was/is a crossflow problem that can develope where one tank fills the other that requires pump replacement to fix ($$$) but you can live with it easy enough too.
It should fire up, run, and drive fine.
Old Aug 24, 2005 | 05:55 AM
80`F-150's Avatar
80`F-150
Thanks for all the help.Its a 4 spd manual. I`m going to look at it in a coulple of hours. thanks again
Old Aug 24, 2005 | 06:07 AM
quicklook2's Avatar
quicklook2
oil pan for rust, oil pressure the gauge is an idiot light, radius arms and bushings, hidden rust under truck, get a good light and look at everything. great engine if maintained well.
Old Aug 24, 2005 | 05:28 PM
gravedigger's Avatar
gravedigger
If the fuel tanks don't work the way they should, that year was coverd under A recall. I got two new pumps on mine
Old Aug 24, 2005 | 05:35 PM
andym's Avatar
andym
No one's going to honor a recall on a 16 year old truck, unless you know someone at the dealership.
