engine balancing
Old Aug 22, 2005 | 10:08 PM
mattselland's Avatar
mattselland
engine balancing
Hey guys i got kinda a stupid question, what exactly does engine balancing consist of? I bought a set of hypereutectic pistons for my 400 today and it needs to be ballanced since they are flat tops, but ive never had a motor ballanced before. Also what is the general price range? Thanks
Old Aug 22, 2005 | 10:33 PM
99f350sd's Avatar
99f350sd
Depends how much heavy metal the crank needs $$$$
All the rotating weight is balanced to be the same. The crank and flex plate and damper are balanced together according to spec's. Sometimes there are race and street specs for crank balancing.. I used to get mine done for about 300.00.
Old Aug 23, 2005 | 06:42 PM
mattselland
ouch, is this absolutely necessary if i go to a flat top piston?
Old Aug 23, 2005 | 07:24 PM
99f350sd's Avatar
99f350sd
When ever you change anything you should get it all rebalanced definetly unless you want a paint shaker..
Old Aug 23, 2005 | 09:03 PM
mattselland
well then i guess this projects gonna be put off till i can come up with 300 bucks. @#$%!
Old Aug 23, 2005 | 09:11 PM
99f350sd's Avatar
99f350sd
You weigh the old piston and rod if the new piston and rod are the same then you are ok.. each piston and rod should be the same.. if they are slightly off you could do some of the work yourself by taking metal out of the heavy ones to = the lightest one, basically the new piston should be within a gram or so of the old...Do some reading on it its interesting.. The whole mess is counter balanced by the crank webs they drill holes and add heavy metal. Each engine has its own balance characteristics..
http://www.centuryperformance.com/balancing.asp
Dick
Old Aug 24, 2005 | 12:53 AM
discman's Avatar
discman
I only paid 150 bucks for my balancing.
Old Aug 24, 2005 | 02:10 AM
monsterbaby's Avatar
monsterbaby
most times hyperectic replacement pistons are pretty close to stock weight (but you can measure that to be sure) and there isn't enough difference to bother anything with an engine that never sees over 5000 rpm.
around here (and most places that I have seen for that matter) it's $150 to balance an engine plus the cost of whatever mallory they use but if you allow them to do the balancing externally usually the 150 will cover it.
Edit BTW mallory metal is very expensive right now because it's the same stuff they make armour plating out of so there seems to be a high demand for it right now.......go figure.
Old Aug 24, 2005 | 02:31 PM
mattselland
so there is hope, i really doubt this motor will ever see 5000, Ill weigh them once i get them and see what comes up. This motor doesnt have to go 20 miles a day, It just has to make passes through the mud pit. Thanks for all the help
Old Aug 26, 2005 | 05:07 PM
460me's Avatar
460me
180$ here,my piston where a gram off
'79 460
Old Aug 26, 2005 | 06:23 PM
zs_tx's Avatar
zs_tx
balance my engine? have a hard time balancing my check book - not much equals 0... lol
Old Aug 27, 2005 | 01:19 AM
Torque1st's Avatar
Torque1st
Posting Legend
If you want to do any high RPM passes thru the mud pits a good balance job will pay off.
Old Sep 14, 2005 | 05:04 AM
oldmaninva's Avatar
oldmaninva
If all you are changing is the pistons weigh the old and new ones. If the new ones are heavy'er by more than a gram I would have them balanced. It is fairly easy to do yourself depending on how much material you need to remove. Find the "lightest" new one and lighten it to within a gram of the old ones then bring the others to the same weight. The "Static" balance part is relativey easy, It's the dynamic part that requires the proper machine and most of all PAITENCE!
Old Feb 24, 2006 | 11:21 PM
weldingfreak's Avatar
weldingfreak
where around centerville, ottumwa would the balance engines I have an 1984 460 I would like balenced
did not mean to just jump in there in there like that
Old Feb 24, 2006 | 11:33 PM
monsterbaby
Well the guy that does my balancing is in melcher, but I just send my stuff to him through napa here in chariton, since the guy that runs the napa machine shop is the son of the guy in melcher that does the balancing.
As far as who does balancing in ottumwa or centerville, just ask the machine shop you use, most likely they will know because most likely they have sent stuff to them to be balanced if they do any racing engine machining at all.
