Dana 205 Emergency Brake
Ive never even heard of such a thing, what a cool idea......
Just kidding High Angle Driveline can do it:
http://www.highangledriveline.com/E-...plications.htm
http://www.ifsja.org/cgi-bin/ubbcgi/...;f=16;t=001659
Originally Posted by FordPickup460
So would that be for parking only or is it strong enough to use as an emergency brake to lock the rears up?
Originally Posted by 78Extended
i need it for a parking brake to pass inspection on my crew cab because i put a disc brake conversion on the rear.
It wouldnt surprise me at all......
Originally Posted by olfordsnstone
Icicle, is that system usable as a driveline retarder? Probably not but if so would be nice while towing on long downgrades.
Not based on what Ivan said:
Originally Posted by ivanribic
only at very SLOW speeds because the heat generated will be tremendous and would burn it up in no time. Plus with a pinion brake if you have an open diff and one wheel is not getting as good traction as the other it'll just keep spinning. Realistically this is not something you'd ever want to use as a driving brake but it could be done.
I did the same and was looking at this page
http://www.off-road.com/ford/bigbroncos/tech/reardisc/
It states that you can use a rear caliper set up from a cadillac eldorado. It has a provision for a "manual" parking brake.
