High speed cooling problems
Old Aug 22, 2005 | 02:31 PM
BigDmoney's Avatar
BigDmoney
My truck get real hot as highway speeds and fine at lower speeds, it also gets hot when the air is on. I just replaced the clutch fan. Its a 88 w/ 302, auto, 110k. Anu ideas?
Old Aug 22, 2005 | 03:19 PM
jtmerritt's Avatar
jtmerritt
What condition is the inside of the radiator in as far as mineral buildup on the tubes? Have you flushed the cooling system and refilled with a 50/50 mix? How about the lower hose, any chance the spring has been removed causing it to collapse at higher speeds. What about the engine timing? Have you cleaned the condensor and radiator of any dirt and bugs?
John
Old Aug 22, 2005 | 05:07 PM
BigDmoney's Avatar
BigDmoney
I checked the condition of the coolent, it seems fine. I did not see bugs or junt on the radiator itself either. I checked to see if there was a spring in the bottom tub and I did not fell one. So that may be the problem. Its just odd to me because it has just started recently, and its only at high speeds. Seems like thats when it should be at its coolest.
Old Aug 23, 2005 | 11:40 AM
Steina's Avatar
Steina
CO River Rat
A good rule of thumb -
If overheating at idle, suspect the water pump;
If overheating at highway speeds, suspect a restriction/blockage in the system.
Steve
Old Aug 23, 2005 | 12:53 PM
BigDmoney's Avatar
BigDmoney
I am going to do the thermostat tonight, I dont think it is fully openiing... what do you think of that therory?
Old Aug 23, 2005 | 01:51 PM
Steina's Avatar
Steina
CO River Rat
It couldn't hurt, and if that doesn't fix it you're not out much money.
Steve
Old Aug 29, 2005 | 12:09 AM
one-shot24's Avatar
one-shot24
not right.. the stat is probably stuck fully open or else it would over heat at the same rate no matter what the speed. if the coolant flows to quickly it doesnt have the time needed to lose the heat from the engine during the time the coolant is in the rad..i had this prob.... not just blowing smoke..
Leef250
Sep 10, 2016 08:45 PM
belchfire
Jun 29, 2016 10:31 AM
Joecjr
Jan 7, 2016 09:30 PM
tgspencer
Aug 9, 2015 06:25 PM
happscrap
Nov 23, 2014 09:23 PM
