edelbrock performer products(carbs, intakes, cams) are for going slow. Try something a little smaller like a 750 or 770 SA. Heck my holley feels like it has 15-20 hp over my edelbrock.
Here's Holley's carb cfm formula:CFM=CIDxmax RPM/3456. That assumes 100% volumetric efficiency(not likely with a street motor) so you need to multiply your result by 85% to 95% depending on the overall efficiency of the engine.85% is a safe spot for a mildly hopped up motor. So...(6000rpm redline)at 100% VE=698cfm; 90%VE=628cfm
FWIW on a similar 390 I had, I used a 650 Holley double pumper that worked very well. The present 428 needed more, so I am using a 750 cfm Holley vac sec.
I have a 650 demon on my 390. Runs good on the street. But when I get in the mountains it gets a little sluggish on me. I am considering going with a 600 cfm.
--stegmst--
Do you have a "Speed" Demon? According to the Barry Grant website, our trucks should be using the "Road" series Demon for daily driving, towing, etc. Unless you drag...the "speed" Demon might need to be de-tuned for your application...which could be part of it...
I've been looking into the "Road" "Trucker" Demon in a 625cfm. Still undecided...
--Anyone--
Why would dropping cfm from 650 to 600 improve the sluggishness stegmst is having? Does it have to do with the altitude and the thin air?
I think I'm just going to put a T-76 turbo on the engine, with a 750 holley - just for the fun of it. I'm looking for 800 Hp ( I have to tow a small trailer) hehe
