Got a noise, need some help
Old Aug 22, 2005 | 06:17 AM
Technitom's Avatar
Technitom
Veteran: Navy
Ok fellas, got a noise coming from under the truck when hitting bumps... sounds feels like its right under the back seat (crew cab) I checked the shocks (replaced at 55k) lookin for a loose one, I've got new ball joints, I checked the exhaust and exhaust hangers, fuel tank, brake lines, sway bar... I'm thinking it might be the carrier bearing??? The u-joints seem to be in good shape, 85K miles on the beastie, just went out of extended warranty (of course!) on 8/11... got any ideas??
Old Aug 22, 2005 | 08:36 AM
Kwikkordead's Avatar
Kwikkordead
Cab mounts good? Coming from under the back seat makes me think that one of the bolts is loose or a bushing is failing.
Old Aug 22, 2005 | 12:02 PM
tjbeggs's Avatar
tjbeggs
i know you said you thought it was under the cab but check the bubber bushings holding the sway bar to the axle. if they move at all replace them. i am not talking about the sway bar links that go up to the frame but the bushings on the front axle. might be the prob.
Old Aug 22, 2005 | 11:18 PM
Technitom's Avatar
Technitom
Veteran: Navy
thanks for the tips! I'll crawl under there later tonight while I'm at work
