Shift kits....
Old Sep 17, 2002 | 04:38 AM
theonlybull's Avatar
theonlybull
Shift kits....
Old Sep 18, 2002 | 09:00 PM
mikeberman04's Avatar
mikeberman04
Post Shift kits....
i got another ? for u guys. what exactly do shift kits do? i have no idea. so someone please explain to me. thanx
Old Sep 18, 2002 | 09:12 PM
Ferrite's Avatar
Ferrite
Shift kits....
A shift kit is typically a modified valve body in the
transmission. It reroutes the fluid to provide firmer shifts.
Racers use it for faster shifting, truckers use it for more
control over shifting while towing or hauling.
B&M makes two popular varieties. The shift improver kit is
simply a separator plate for the valve body. The "Transpak"
is a full valve body modification with a few different levels
of intensity depending on what you want.
I have the Transpak in my C6 and love it.
-Ferrite
Old Sep 18, 2002 | 09:24 PM
mikeberman04
Shift kits....
yeah, i have a c6 also. how much do they range from, those B&M ones that u got. is it something i can put in or do u need to take the tranny off? thanx
Old Sep 18, 2002 | 09:39 PM
LxMan1's Avatar
LxMan1
Shift kits....
The Shift Improver kit runs under 30 bucks. The Transpack The better of the 2) usually runs between 60 and 75 bucks.
They can be installed without pulling the tranny, but you must remove the pan and the valvebody. It's kinda messy, but not a bad job. Just read the instuctions a couple of times before you start, that way if you run into something that you don't understand, you can get some help before you are stuck in the middle of the job.
Jimmy
Old Sep 18, 2002 | 09:53 PM
Ferrite's Avatar
Ferrite
Shift kits....
Yeah, I think mine cost 50-something when I got it.
summitracing.com, or most parts stores can get them, too.
As said, just follow the instructions that come with it.
It'll walk you right through no problem. Take your time.
-Ferrite
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
