shift lever removal???
Old Sep 17, 2002 | 11:01 PM
Kenworth's Avatar
Kenworth
Old Sep 18, 2002 | 11:06 AM
smaynor's Avatar
smaynor
Question on how to remove the shifter from a 1975 F-250 with the "granny" 4-speed. Does in unscrew from the top of the transmission, or do I drive out a pin, or ???. I want to remove the lever so I can paint it, but I'm not sure how it comes off.
Any help appreciated.
Stacey
1975 Crew Cab
Old Sep 18, 2002 | 11:20 AM
jalampi's Avatar
jalampi
If its a T18 unscrew the retainer, A NP435 push the retainer down and turn it.
1979 F350,4x4,NP435,5:13 gears,Detroit locker in rear with hardened shafts,ABR in the front,L&L Ladder Bars,360 with 428 crank & rods,390 HP heads,Centerforce Dual Friction Clutch,MSD Ignition,39.5x18 Boggers,bucket seats out of a Lightning,& a Southern Body that is perfect.
1997 F350 PowerStroke 4X4,36 Inch Super Swampers, Strait Piped, Chiped, Propane Injected, LUK Clutch
Old Sep 18, 2002 | 02:32 PM
smaynor's Avatar
smaynor
Sound simple enough...Now how do I tell the difference between a T18 and a NP435???
Just in case you haven't figured this out already, I'm a former chevy guy. :P
Stacey
75 Crew Cab
Old Sep 19, 2002 | 07:07 AM
jalampi's Avatar
jalampi
The top of the trans where the shifter is aluminum on the NP435. The T18 is cast iron.
Aerostar
Aug 21, 2024 11:23 PM
bradphx
67
Jan 10, 2024 06:12 PM
miko6810
Modular V10 (6.8l)
Jun 4, 2014 06:14 AM
Oklahoma Chapter
Apr 11, 2003 10:33 PM
walterdanek
16
Feb 16, 2001 07:56 PM
