Sponsored by: Real Truck
Auto locking hub problems
Old Aug 22, 2005 | 03:45 PM
RobertJohn's Avatar
RobertJohn
IMHO....it's a vacuum problem .....
Thats why I'm wanting to know which line to plug..
Old Aug 22, 2005 | 04:04 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
The black line that goes from the solenoid to just past the battery and drops down below, that's the supply from the solenoid to the hubs. At the right angle elbow, I seperated it and plugged both sides.
The red one going to the solenoid is from the vacuum resevoir - it is t'd with the heater box. The vacuum resevoir is supplied with a red line coming from the engine.
Remember, the hub's vacuum fitting is basically a breather for the inner hub now. So, if you see lots of water/mud/snow, it might be better to plug it right at the hub instead just in case one of the (now useless) vacuum hoses brakes and sucks in liguid... It would have to be a metal plug, to make sure it doesn't get dislodged in rough situations
Old Aug 22, 2005 | 04:26 PM
IB Tim's Avatar
IB Tim
Originally Posted by flatfnder
I have a 2005 F250 Superduty, after driving off the lot and 5,000 miles later (hadn't put it in 4 wheel drive yet) I noticed that my front drive shaft was turning when I was driving so I checked both front hubs and both where turned to auto. I jacked up the front end and sure enough both hubs where locked. I played around with both the hubs and was able to get them to unlock but am worried about the future. I have a buddy with a 2005 and he has been having problems with his hubs not wanting to unlock as well when taking it out of 4 wheel drive.
...Welcome to Ford Truck Enthusiasts! Take a moment to read the Guidelines, it will help you to navigate through and understand this site.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Aug 22, 2005 | 06:36 PM
IB Tim's Avatar
IB Tim
...Welcome flatfnder, to Ford Truck Enthusiasts! Take a moment to read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
Enjoy FTE....and
greenman0013
Feb 20, 2017 08:32 PM
Big Sky
Apr 28, 2011 10:16 PM
emal
6.4L Power Stroke Diesel
Oct 27, 2010 04:19 PM
koboss1
Nov 22, 2008 11:18 PM
CNF250
Jul 26, 2005 05:48 PM
