Engine won't turn over
Old Aug 20, 2005 | 10:18 PM
Artbo's Avatar
Artbo
86 f-250, 460, auto trans.
Won't crank with key.
Replaced solenoid, starter switch and adjusted neutral start switch.
Remote/ jumper wire starts fine.
Old Aug 20, 2005 | 11:10 PM
MemOrex's Avatar
MemOrex
Sounds like the wire going to the solenoid from the Key ignition is broken or something. Have someone hold the key in CRANK and check voltage at the wire.
Old Aug 21, 2005 | 12:53 AM
Lead_Foot's Avatar
Lead_Foot
wrong forum, you want the 80-86
