Electrical nightmare
Old Aug 20, 2005 | 07:55 PM
bobznnm's Avatar
bobznnm
I have a '93 Ranger 2.3L with about 291,000 miles, one owner, maintenance maintained since purchased, and this problem arises....the truck doesn't seem to want to start in the mornings, just a clicking noise but nothing else, it can be jumped by another battery, and it runs a starts fine throughout the day til the next morning. The starter is about 3 yrs old, the alternator is also about 3 yrs old, battery is new, battery cable is on order for the next 3 days......any suggestions or solutions appreciated.......bobznnm
Old Aug 21, 2005 | 12:09 AM
jcp123's Avatar
jcp123
Sounds like the battery cables are corroded. Take them off the battery and clean them and the battery posts, and you should be good to go. Hope this helps.
Old Aug 21, 2005 | 12:23 AM
Birdhunter1's Avatar
Birdhunter1
Could be a very very small short somewhere in the vehicle too.
Old Aug 21, 2005 | 01:27 AM
Crash687's Avatar
Crash687
try running a new ground to the engine from the battery if your battery voltage is around 12.5 in the morning
Old Aug 21, 2005 | 02:19 PM
rebocardo's Avatar
rebocardo
On a vehicle with that mileage and the year, new battery and alternator cables are in order, especially in a snow state where they salt the roads.
That being said, it sounds like a short or something as simple as the brake lamps staying on are draining the battery overnight. You might want to check the alternator for a bad diode, especially if you used the truck to jump start someone recently.
Old Aug 22, 2005 | 10:04 AM
pawpaw's Avatar
pawpaw
I'd run this puppy by your favorite auto parts store for a no cost electrical system check up, via their portable electrical system tester.
It can check ALL the systems components in the vehicle while under load & check for excessive parasitic electrical drain, with everything turned off.
Sounds like something is draining the battery over night, so a lamp staying on, or a shorted alternator diode, shorted battery cell, ect, ect, sounds likely, so the portable tester should be able to sniff it out.
Let us know what they find.
Old Jul 23, 2006 | 07:38 AM
sfcwoodret's Avatar
sfcwoodret
It sounds like you got the best out of that vehicle, and an upgrade is an option.
Old Jul 23, 2006 | 02:53 PM
ericsmith32's Avatar
ericsmith32
Try new battery terminals and don't get the cheap ones. My aspire would start fine with a jump but wouldn't start off of the battery. I just replaced the terminals a couple months ago with the cheap ones, the last time i'll do that.
Old Jul 23, 2006 | 04:25 PM
Bob Ayers's Avatar
Bob Ayers
Your symptoms sound like a battery drain. Pull the negative battery cable, and put a test light between the cable & battery terminal. If the light lights bright, there is a substantial battery drain that should not be there. Then start pulling fuses (one at a time) till you find the circuit that's pulling too much current (test light will dim).
Old Jul 23, 2006 | 09:09 PM
jimdandy's Avatar
jimdandy
Smile
A battery with a "dead cell" will exhibit this symptom. jd
