Sponsored by: Real Truck
SD Rear leaf upgrade
Old Aug 19, 2005 | 09:05 PM
Ed the Builder's Avatar
Ed the Builder
Question SD Rear leaf upgrade
I own a 2003 350 SD PSD. It is currently rated at 9900 GVW. I want to replace rear leaf springs w/ Ford oem springs rated higher. Has anyone done this and how did you know which springs would fit?
Old Aug 21, 2005 | 07:59 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Aug 21, 2005 | 11:36 AM
99f350sd's Avatar
99f350sd
Iwas gonna do that and I chose to go with timbrens . I think it was a smart choice.
The truck rides like stock but when I load it up it goes down and inch or so and no more and rides fine.. and for $200.00 with lifetime warr and 15 min install its a no brainer..
Dick
Old Aug 25, 2005 | 07:57 AM
Antacus's Avatar
Antacus
99f350sd, did that raise your truck up from stock height at all? If so how much and did you need to change out the shocks?
Old Aug 25, 2005 | 09:20 AM
99f350sd's Avatar
99f350sd
No it does not raise it up. they don't come into play until the truck goes down an inch or so.
Dick
