The 9000x's work great on a stock vehicle. I would have put another set on mine after the lift, but they don't make them for anything bigger than a 4" lift. I REALLY liked 'em. I had the in cab controller, but never installed it. A few bud's of mine had it and constantly had problems with air leaks and broken air lines (escpecially when it got cold)
my 2002 F-350 does not have the stabilizer shock
I see the mounting location, but the shock is missing
Do F-350 have the steering stabilizer?
I am thinking it was removed by the former owner and never replaced
All SD's have the mount on the axle housing, the mounting bracket on the drag link is not there if your truck didn't come with a stabilizer to begin with.
Could I get some recommendations on good shocks and steering stabilizer? Time to make her ride and drive like new.
Is your '03 totally stock? Is it 2wd? or 4wd? What changes, if any, have you done to the suspension? What changes, if any, do you plan for the future? Need more info so we can steer you in the right direction (no pun intended!)...
