Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Jack release solution
Old Aug 18, 2005 | 11:31 PM
mjunk1's Avatar
mjunk1
Lightbulb Jack release solution
I love my floor jack and compared to other scissor jacks there is no contest. However - I HATE the little bolt that releases the pressure. Does anyone have a great/quick modification that makes releasing the pressure easy/controllable?
Old Aug 19, 2005 | 12:50 AM
Torque1st's Avatar
Torque1st
Posting Legend
Most jacks from the factory work real well. Unfortunately most people over tighten the release screw and ruin the seat. It just takes finger pressure to tighten the valve. My jacks live a long time and release very smooth but I do not let ANYBODY use them.
Old Sep 30, 2005 | 05:02 AM
pursang's Avatar
pursang
More torque ! make a "T" handle so you have more leverage.
Old Oct 1, 2005 | 03:18 PM
Mr.Ford 351W's Avatar
Mr.Ford 351W
buy a craftsman 3 1/2 ton jack or a 4 ton!!!!!!!!!
Old Oct 1, 2005 | 05:31 PM
Greg 79 f150's Avatar
Greg 79 f150
Pursang nailed it already. Get creative. Take a solid 1/2 steel dowel rod and drill the end out so it will fit over the release button. Crosscut a slot on that hole to fit the roll pin tee on the button. Make a bracket and attach it to the handle so the dowel can be made long enough to almost reach the handle grip and you will not have to bend over to reach it. Or maybe do like I did if you are fat and dont bend in the mid section anymore too well. Buy a floor jack in which you just turn the handle to set/release the valve.
