1966 S-code 390 specs please!
Old Aug 18, 2005 | 09:35 PM
optikal illushun's Avatar
optikal illushun
Anyone have or know where i can locate specs for a 1966 S-code 390? its found in cars and makes 335hp/427lb-ft torque.
im looking for intake/exhaust valve sizes, possible stock head flow and cam specs.
thanx!
Old Aug 19, 2005 | 12:02 AM
fordeverpower's Avatar
fordeverpower
Its my impression this is a gt model. The heads are fairly standard. I think the have the extra bolt holes on the exhaust but thats about it. The valve sizes should be 2.02/1.55. These heads should flow about what c8ae-h and d2te-a flow. Kurt, has a set of flow figures and the ones I use are below.
heres what i got for cam specs same as 428cj
270/290
.481/.490
46 overlap
seat
18 72
82 28
(-30) 22
28 (-24)
I am not a 100% sure the cam timing is right there.
There are many better cams today than old factory techno.
Heres what i use for head flow:
.100 63 46
.200 115 88
.300 168 120
.400 193 138
.500 202 143
.600 207 145
Old Aug 19, 2005 | 12:41 AM
optikal illushun
thanx!!!...
Old Aug 19, 2005 | 01:12 AM
Bear 45/70's Avatar
Bear 45/70
fordeverpower is correct (the cam specs are close enough) and the GT heads have the stagger exhaust bolt pattern. The engines also came with a 600CFM Holley with vacuum secondaries. The stock exhaust manifolds for these engines were not the standard log type and flowed a lot better.
Old Aug 19, 2005 | 08:23 AM
russrobbins's Avatar
russrobbins
Plus the GT head had a better valve spring than the regular heads.
Old Aug 19, 2005 | 11:49 AM
bertha66's Avatar
bertha66
I run a 67 GT engine in my 66 4x4, this is a great engine, gets good mileage and has more power than I need to get into trouble with.
Mercmeister
38
Mar 27, 2022 11:45 PM
Philip Land
Nov 1, 2015 10:55 AM
jayden1d
Jan 24, 2013 01:31 PM
JimNolan
Jan 26, 2010 05:47 PM
pkulaga
20
May 10, 2006 03:36 PM
