Electrical Problem
Old Aug 18, 2005 | 04:39 PM
67aj's Avatar
67aj
Unhappy Electrical Problem
I have a 1994 F150 and is havings electrical problem. My horn and cruise control have stop workings. I have check all fuse and relays and they are good. Need help in solving problem. Thank.
Old Aug 18, 2005 | 06:56 PM
Franklin2's Avatar
Franklin2
If you have the cruise and of course the horn on the steering wheel, then the most likely cause it what they call a clockspring, that is in behind the steering wheel. This thing sends the electrical signals to the steering wheel, while still letting the steering wheel rotate. After awhile they break.
Old Aug 19, 2005 | 07:21 AM
67aj's Avatar
67aj
Question Electrical problems
Is the clocksprings easy to change out or is it's better to take to a repair shop. Where is it's locate in the steering wheels.
Old Aug 19, 2005 | 04:20 PM
Franklin2's Avatar
Franklin2
Here's a procedure for taking the steering wheel off.
http://www.autozone.com/servlet/UiBr...3d800a9e20.jsp
I have never replaced the clockspring, but from the description of other guys who have done it, it's pretty simple once you get to it. The hard part is getting the steering wheel off.
