93 intermittently won't start
Old Aug 18, 2005 | 02:15 PM
bigsheldy's Avatar
bigsheldy
Hey guys, just signed up today so I'm a complete newb. I just bought a 1993 Ranger 2.3L 2WD, and I've been having trouble starting it sometimes. The ignition cylinder (I think that's what it's called, its the metal thing you put the key in ) spins all the way around, and it's really hard to get my key in sometimes. I eventually figure it out, but there's times when the car just won't start at all. It's really confusing to me, because I've never heard of something like this. There's no clicking noise, the engine doesn't turn over, it just sits there, like it's in the ACC position. The guy before me gave me a new ignition cylinder to put in, but I haven't had any luck removing the current one, and my Haynes and Chilton's manuals don't help at all, not to mention I don't even know if this is the problem. I've tried searching the forums here to no avail, so any help identifying the problem or install the stupid thing would be great.
Old Aug 18, 2005 | 07:38 PM
Ken00's Avatar
Ken00
Welcome to FTE!!!!
I don't have my early 90s manual with me but you normaly put the switch in the run position and push in the release pin, mine is shown on the underside of the column. Fix it now, if it stops working when it's not in the run position you will have to drill it out.
Old Aug 19, 2005 | 04:55 AM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
Welcome to FTE!!
If you do some searching under my screen name, you should find the details on how I replaced one on my former 94 back around Oct or Nov 2004. And yes, if you ignore that ignition cylinder, eventually you just may be stranded. As for the no crank condition, I'd suggest inspecting the battery cables, voltage to the solenoid, the solenoid itself, grounding, and finally the starter. I'll assume that you have checked the battery and it's good. Let us know what you find.
Old Aug 19, 2005 | 12:35 PM
jinx102672's Avatar
jinx102672
I'd agree that checking your battery cables and the like would be a good idea, I would also highly suspect that if you can turn your ignition lock cylinder completely around, that the contact points inside for the ignition signal are probably close to being shot, and that's why it wont start.
Ndurbin10
Apr 1, 2014 07:17 PM
49er_rs
1997 - 2003 F150
Nov 9, 2012 08:54 AM
manofsteel52
1997 - 2003 F150
Apr 26, 2010 03:28 AM
jimjoebob99
67
Nov 2, 2009 01:09 PM
dcdave
20
Mar 11, 2007 10:52 PM
