steering bushing
Old Aug 31, 2002 | 02:11 AM
ackusackus's Avatar
ackusackus
steering bushing
I believe there is supposed to be some sort of bushing on the steering column between the steering box and the fire wall.....I hope.... Any way, I currently have about 40 degrees of play in my steering, and I traced it to this one spot. I checked my manual and came up empty handed. Can anybody help fill in the blanks, and point me in the direction for a procedure to replace this? I am sick of driving like a drunk thanks to all the slop in my steering....I have a 77 150 2wd w/ 460/c6.
thanks,
ackus
Old Aug 31, 2002 | 08:09 PM
Mike W's Avatar
Mike W
steering bushing
It's called the rag joint. It stops vibration from getting to the steering wheel. I loosen the steering colume and pull it up a little to replace the joint. You can also replace the rubber piece by itself.
Old Aug 31, 2002 | 08:31 PM
ackusackus's Avatar
ackusackus
steering bushing
do I do the same procedure to just replace the rubber? I think that is all that needs to be replaced. And I am going to sound stoopid here, but when you say loosen the steering column, what does that entail? I have a pretty crappy manual when it comes to the steering stuff.
Old Aug 31, 2002 | 09:03 PM
30over's Avatar
30over
steering bushing
Hey Friend, I was able to replace the rag joint on my 76 2wd F250 without moving the column back although that would probably make it easier. It has been awhile since I did it but seems like it wasn't to much of a nightmare. You can usually find those rag joints in the "HELP" section at most chain parts stores like Advance & Autozone. You know, in the isle where all the little red packages that say "HELP" are hanging. Hope this helps.
Old Sep 25, 2002 | 07:05 PM
ackusackus's Avatar
ackusackus
steering bushing
okay, I got the rag joint, and I have 2 bolts off....There are 2 other..."things", that are perfectly round (not wrench friendly)... They are part of 4 total "connections bewteen the steering column and the steering box. Where do I go from here? Remember, I am a noobie, and I have never done something like this before.
thanks
ackus
Old Sep 25, 2002 | 08:42 PM
Mil1ion's Avatar
Mil1ion
steering bushing
2x4 automatics have a slide joint on the end of the column ( 12 point nut holds it tight) that joins to the rag joint and stering box.
4x4's have a shaft with u-joints on it that joins to the column this too has a 12 point nut that loosens to remove the column.
I bet you think that 12 point nut is round !
[font color=red]Dennis
FTE Assistant Administrator
[/font]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
Old Sep 25, 2002 | 10:07 PM
ackusackus's Avatar
ackusackus
steering bushing
oh its round. These two "bolts" are very round...I cleaned them up to make sure of it (then cursed and muttered to myself...so HOW am I supposed to get THOSE off?!?!?!?) These 2 bolts run parallel to the steering column and are part of the joint. I did see a bolt that appeared to be part of some clamp, and it is between the rag joint and the power steering box. I am hesitant at this point to touch that as I do not know what the consequences would be.
Old Sep 25, 2002 | 10:12 PM
Torque1st's Avatar
Torque1st
Posting Legend
steering bushing
