Sponsored by: Auxito
Power Window Help
Old Aug 17, 2005 | 06:50 PM
hazurdous's Avatar
hazurdous
Power Window Help
Today the drivers side window decided to stop working in my F150 2001 Supercrew. All the other windows work fine when controlling from the drivers control panel, except for the drivers side window. When i press down on the switch, I can here a clicking sound and it sounds like its coming from the fuse box, but the fuse is fine. Any help would be greatly appreciated!!
Old Aug 18, 2005 | 06:01 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Aug 18, 2005 | 07:43 AM
l-m tech's Avatar
l-m tech
the clicking you hear could be a circuit breaker tripping because the window is stuck,or a relay that is trying to send power to the motor.to get it unstuck i usually remove the door panel and smack the door where the motor is while pushing down on the switch,that usually frees up the motor.if that dont work the switch could be bad ,or motor.
Old Aug 18, 2005 | 09:05 AM
christaylor's Avatar
christaylor
I have to do the same thing from time to time to get my driver window up. I can now have the door panel off and back on in under 3 minutes.
Old Aug 18, 2005 | 11:26 AM
gpeade's Avatar
gpeade
it sounds to me that you need a new motor. you can get one from ford but I would go with a napa remanufactered less than $75. If you are a do it yourselfer it can be done in about an hour or less.
