Blinking Overdrive Light
Old Aug 17, 2005 | 09:09 AM
McHarward's Avatar
McHarward
95 PSD AUTO 7.3, While towing last weekend the overdrive light on the gear selector began blinking. What caused it and what can cure it? Thanks for any help.
Old Aug 17, 2005 | 09:43 AM
wlihntr's Avatar
wlihntr
a blinking OD light is the "check engine" for the trans. you should get it scanned to see what codes are stored
Old Aug 17, 2005 | 10:02 AM
02PSD4ME's Avatar
02PSD4ME
Check you ABS speed sensor, it is located on top of the rear axle. Around $20 to replace, and I think it is 2 10mm bolt that hold it on.
Had the same thing happen on my old 350.
Old Aug 17, 2005 | 04:29 PM
McHarward's Avatar
McHarward
Thanks I will look into it
