steering box difference ?
Old Sep 28, 2002 | 08:34 AM
supercab78's Avatar
supercab78
Does anyone know if a steering box from a reg. cab is the same as one for a supercab? I have a 78 F-250 supercab & hoping to install a slightly used rebuild from a 77 reg. cab. Other than the line fittings maybe being different I was hoping it would be the same. I was thinking maybe the turning ratio could be different. They are both PS boxes. Thanks Jeff.
Old Sep 28, 2002 | 10:43 AM
tetraruby's Avatar
tetraruby
I don't know the answer, but try calling your local parts store(s) and ask them if the same part# is called for in both applications. A reply post of what you find maybe beneficial to someone else.
Old Sep 28, 2002 | 02:49 PM
fatdaddy's Avatar
fatdaddy
The cab(s) , crew , super , or regular , is irrevelant as far the steering box is concerned , what counts is f250 to f250 , 2whdr or 4 whdr , and the year model to year model in terms of compatability of parts is concerned---a 77-f250 , 2wh dr steering box should work on a 78-f250 , 2 whdr-----just remove both and compare them , side by side , that should tell you quickly how much alike they are.........fd
Old Sep 28, 2002 | 05:33 PM
78f250lj's Avatar
78f250lj
