Another air compressor question.
My problem is that there isn't a whole lot of room in the garage for a decent size compressor (to handle sandblasting and such). I would have to rearange some work benches and shelves to fit one in where I would want it to go.
I was wondering if it could be stored in a shed or somthing outside and have the air lines run into the garage. If I was in worm climates I would do it no questions asked but I live in New England and it gets cold here. Would this be a bad idea or would it be ok as long as I let all the air out in the winter after I was done using it.
I tried to search for this and had no luck in finding an answer.
Thank you
Oh yes...I live in Canada (used to live in Northern Ontario with this same setup) so a cold winter climate shouldn't be an issue.
I used to have a 2 hp craftsman -splash oiled cast iron w/ 20 gallon tank...didnt really seem to bother it too much in unheated garage..until it got below about 15...then let you know it didnt like it.... by making more noise than usual...sometimes squeeling the belt....lighter oil in winter may have helped....didnt use a lot in winter....lasted me 30 years.
Now have a 7-1/2 hp Ingersol-Rand 2 stage w/80 gallon tank.....tried it once...it squeels the belt when cold ...even with the factory I/R synthetic oil...wouldnt risk a rod thru the block....after that...read the manual....it says dont operate below 40 degrees
Ok now next. What about the plumbing from the compressor to the inside. If I burry a copper line would it be fine or would it freeze due to condinsation in the line. I know a compressor makes condinsation but would there be enough in the line to freeze it up. I am thinking of putting this compressor about 20 feet from the garage. The land layout only allows it to be here. I got a portable drive through tent on teh side of the garage and want to put the shed/enclosure on the side of the tent so I can still use it as a drive through to the back yard.
and thank you so far for all the info. I am yet again amaized withthe knowledge on this board and the helpful people.
Also, if you are going to be driving over your air line, burying it deeper would be better or put it inside a bigger piece of pipe such as Schedule 40 or 80 PVC. That way you won't have to worry about crushing it. Probably want to put stone dust or sand around the pipe and not backfill with rocky soil. Probably overkill but beats digging it up again.
What part of Cow Hampshire you in?
I was planning on burrying it and had a thought last night of putting the copper line inside PVC before burrying. I have a propain line already burried in the same area. It dosen't get driven over constantly but will still be driven over on occasion.
I was also thinking of somehoe tapping off the prorain tank(probably call the propain co. for this) to power a small heater or somthing. I could probably just run a cord also and light a heat lamp.
I'm 20 minutes north of Hav-er-hill
On hunid days in the summer, the difficulty is that the earth acts as a very good heat sink, and lots of water will tend to condense inside the underground run of pipe from the shed to the garage. You can pitch it towards the garage, but since the line is already underground it will end up being 2 feet down at the garage end. But now you need to bring the air into the garage and up to a level that you can use a regulator/filter/quick connect. If you don't do anything to drain the water, you will end up bubbling all your air through the puddle of water which will inevitably collect at the low point.
My solution to this was to use one of those plastic irrigation valve boxes, a tee, a two foot stub of copper line, and a ball valve, all installed at the low point as the line enters the building. This provides a place with some volume for the water to collect, and access to allow me to drain it out periodically. Still, it is a pain to go outside and reach down into the box to drain the water, especially on rainy days.
I want to pipe the air up into my garage. A pipefitter at work whom I respect tells me he has run PVC pipe into his garage and not had any problems versus black pipe that people traditionally use.
Has anyone else had experience with this?
PVC has a low energy of fracture, and shatters like a pipe bomb if struck while it is pressurized. To demonstrate, obtain a piece of PVC, put on safety glasses, and smack the PVC with a hammer. Note how easily it breaks. Note the shards and slivers of broken plastic. Try the same thing with copper or steel and you will see the difference.
Sch 40 PVC does have an adequate pressure rating for air compressors. It is weakened by any oil that gets past the compressor rings, and heat from the compressor is not good for it, but it doesn't tend to fail unless struck by something. This is why you get anecdotal reports of "not had any problems".
But PVC is unrated for this use, and downright dangerous for any compressed air application except buried underground. Don't run it exposed inside your house.
take a look at rough sketch I did of the layout
http://img.photobucket.com/albums/v252/fx390/pics/shedplacement.jpg
Never use PVC for air lines.
