replacing coil packs
Old Aug 31, 2005 | 02:11 PM
mjamie12's Avatar
mjamie12
Originally Posted by dpkfordtruck
I have a 97 Ford F-150 with the 5.4L V-8 engine. It has right at 110,000 miles on it. Recently I had the throttle body cleaned because the gas pedal had a hard place in it when you first pressed down on it after it had set for a while. That cost $108. The garage said they got almost a coffee cup full of buildup. It ran fine for a while. Now the Check Engine light has come on and it idles and runs very roughly. I took it to a garage and had it checked and they said the coil packs need to be replaced to the tune of $1,400.
Can anybody out there give me an indication as to whether or not this is what needs to be done?
Thanks.
Hope I'm not too late here. It sounds like you might have a bad coil pack. Do not have the garage do them, though. A single bad coil pack can cause your symptoms. If all of them were bad, your truck wouldn't run. A coil pack for my '97 F250 ran about $100 at Auto Zone. They are held on by two screws, which is why paying someone to do this is silly. What you should do is shoot over to Auto Zone and find out which cylinder is misfiring. (If your check engine light is on, they will scan your vehicle for free). If your firing order is the same as mine, start in the lower left as you view from the front.
Should look like this:
BACK
4 8
3 7
2 6
1 5
FRONT
Replace only the coil pack that is causing the problem. The entire job should only take about ten minutes. If it's not the coil pack, and I'd be surprised if it isn't, then you have a truck with a brand new $100 part in it, which isn't so bad. Also, if you have no idea how to do auto repair, buy the part and match it up to the part in your truck. This is how I first learned basic repair.
Old Aug 31, 2005 | 03:10 PM
warmdye's Avatar
warmdye
Alot of times the computer will not throw a code and you will have to manually change each one out until you find the culpret. I had to do that when one of mine when out with no check engine light.
Old Nov 23, 2005 | 11:04 AM
braclark's Avatar
braclark
You can also get the whole coil pack, boot and spring for about $40 at:
http://www.wittydeals.com/product_in...products_id=97
Old Nov 23, 2005 | 01:33 PM
fordguyforlife's Avatar
fordguyforlife
Originally Posted by LxMan1
All 5.4L have COP's 97-up. 4.6L has coil packs 97-98 and COP's 99-up
i'm a little confussed. my dad has a 99' F250LD with the 4.6, and it has coil packs and wires. did ford make the change half way through the model year? or is this just something special for the 250LD?
Winning Windsor
1997 - 2003 F150
Jul 11, 2015 10:06 PM
meade01
2004 - 2008 F150
Feb 6, 2015 11:56 AM
kunard333
1983 - 2012 Ranger & B-Series
18
Aug 24, 2014 11:17 PM
breakinator
Modular V8 (4.6L, 5.4L)
Sep 17, 2008 03:00 PM
jpkoke02
16
Aug 2, 2004 06:17 PM
