Carb tweaking question
Old Aug 16, 2005 | 11:54 AM
natira121's Avatar
natira121
1978 f250 4x4 w/ 428. Headers, 3" exhaust, Performer manifold, and Edelbrock 1406 600 cfm carb
Question: Runs damn good, but when I really get on it, and the secondaries kick in, it bogs a bit... like it's getting too much gas. (And it doesn't keep accelerating like it should) It is running rich by the smell at at idle, though it's smooth. (It pops just a bit when decelerating downhill) I'm thinking of turning up the air a bit. Is this the right thing to do?
Thanks
Old Aug 16, 2005 | 12:18 PM
Freightrain's Avatar
Freightrain
Doesn't these carbs have the "AIR" controlled flap on the secondaries?? My old 500 Carters did?? They kinda made it like a vac. secondary carb by using weighted flaps to ease the fuel on.
I start with idle mix screws 1 1/2 turns out, then slowly adjust in til motor starts to stumble, then back out 1/4 turn. Do both so that they are basically the same turns out.
I've never had a motor backfire while decelling. Don't know if that is a rich or lean condition. Excess fuel in the cylinders could be the culprit? If it was lean, I guess it would pop up thru carb, not exhaust.
Old Aug 16, 2005 | 06:14 PM
Randyb12's Avatar
Randyb12
Is that what the two weights inside the carb are for?
I was trying to figure that out last time I had the top off of my Edel Perf 750cfm carb.
How do they work?
Old Aug 16, 2005 | 07:13 PM
natira121's Avatar
natira121
I got the problem solved.... it was the timing. Also hooked up the vacuum advance (couldn't get it to work right before due to electrical problems making it impossible to get the timing right in the first place) Then it was just a matter of setting the idle fuel mix, and the beast is beastly again!
Keep your fingers crossed on Thursday. I will have a 3000 lb camper on the truck, and will be towing a 3500 lb trailer..... Right up a mountain! *grin*
Old Aug 17, 2005 | 08:37 AM
Freightrain
The air pulls past the plates, trying to OPEN the secondaries. The weights are there to help slow it down. Grinding the weight off thus lets the sec. open quicker. Just like a Holley and the different springs for sec opening...but with Ebok..there is no going back!! Unless you solder metal back on?
BTW, glad you got it figured out natira121.....have fun on the camping trip!
Old Aug 17, 2005 | 10:41 PM
Randyb12's Avatar
Randyb12
My secondaries are mechancail not vac How does that work?.
Old Aug 17, 2005 | 11:22 PM
Bear 45/70's Avatar
Bear 45/70
The throttle plates move as mechanical, just like the Quadrajet. The air valve prevents the air flow and fuel flow until the engine needs it. Just like vacuum secondaries do the same job differently.
Old Aug 17, 2005 | 11:46 PM
Randyb12's Avatar
Randyb12
Hmm... I will have to read up on this. I thought it was a straight mech setup.
Old Aug 18, 2005 | 08:54 AM
Freightrain
Yup, Bear. It gives you both worlds. Mech actuation, but then the air flap regulates the total flow by engine vacuum.
You can take the flap out of the carb, just remove lid and slip it out. This will give you total mechanical. But you will then most likely feel the bog. Since it has only ONE squirter...it will be real lean until it starts to pull fuel.
If you notice ALL Holley mech carbs are DOUBLE pumpers. Giving the additional squirt in the rear to help fill in the lag. Holley made a conversion kit years back that had a special squirter that had tubes that went to rear holes to make a vacuum carb a double pumper. It also had a gear set that mounted on side of carb to convert to mech linkage. Buddy ran one of these years back on race car...it worked!
Bootlegger's Deluxe
Aug 2, 2017 05:09 PM
TheSterling
Feb 9, 2016 11:58 PM
Mister_King
Oct 27, 2014 12:40 PM
BossFan
Aug 17, 2014 07:21 PM
Big_Tom_54
Jun 3, 2014 05:14 PM
