Mostly missing
Old Sep 29, 2002 | 06:06 PM
Vampiro's Avatar
Vampiro
Mostly missing
Old Sep 29, 2002 | 10:55 PM
rfgree's Avatar
rfgree
Mostly missing
I have a '78 F-100 with a 302 that has a miss fifty percent of the time.I have the Duro-Spark which came with the truck. My coil was bad {Arking at the coil boot}. It was really bad before I replaced that. Sometimes it will stop missing on it's own and my speed will increase 5 mph right away. New plugs didn't help. Distributor looks good. Two questions..
1. Can I remove the plug wires at the distributor and test them rather then as the book say's "Remove the plug wires and hold them a quarter inch away from the ground to check your spark or can I check for a spark gap between the plug wire and the plug with an extended piece of metal between the boot and the plug?. I don't seem to have any luck by pulling a plug wire and listen to see If my miss gets worse. Seems like there is hardly a change when I pull any of the plug wires off.
2. Anyone have any secrets on different ways or short cuts to check out a rough running engine? The carb. was just recently rebuilt and I'm 99 percent the problem is electrical. More plug wires didn't help either.
Old Sep 29, 2002 | 11:30 PM
LxMan1's Avatar
LxMan1
Mostly missing
Go to your local autoparts store and pick up a spark tester. They are cheap. They plug into the plug end of the wire and clamp to the engine for a ground. This way you don't get shocked either.
Old Sep 30, 2002 | 12:05 AM
Mil1ion's Avatar
Mil1ion
Mostly missing
Start the engine in a really dark spot and while the engine is running ,look for a *light show* under the hood where the wires are shorting out(if they are).
[font color=red]Dennis
FTE Assistant Administrator
[/font]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
Old Sep 30, 2002 | 05:26 AM
theonlybull's Avatar
theonlybull
Mostly missing
to help with the dark light show, use a spray mister and go along your wires one at a time, sometimes this help show it up
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
