EGR problem - help!
Old Sep 27, 2002 | 03:10 PM
theonlybull's Avatar
theonlybull
EGR problem - help!
Old Sep 30, 2002 | 01:10 AM
kcabpilot's Avatar
kcabpilot
EGR problem - help!
I've got a '78 F250 with 460. It has the original Motocraft carb and the spacer ported EGR system. My problem is that when I start the truck cold I can hear an exhaust leak. It goes away after it's warmed up but it keeps blowing the spacer and carb base gaskets at the right rear corner where the EGR port is. I've had these things off several times and I can't see any warping or anything else on the spacer that would cause this. It seems to sit on the manifold right but obviously something isn't correct.
Is there anything else I'm not catching that could be causing this?
Old Sep 30, 2002 | 02:04 AM
Torque1st's Avatar
Torque1st
Posting Legend
EGR problem - help!
Well....
If the flanges are straight and smooth (not pitted).
If you have removed any studs and cleaned the threads.
If you have used a flat file to remove any burrs or high spots.
If you are tightening (torquing) the bolts properly.
Try a better gasket, one of those metal reinforced asbestos looking jobs.
Old Sep 30, 2002 | 09:16 AM
dfisher1's Avatar
dfisher1
EGR problem - help!
K,
Eliminate the EGR system!
It suites no productive service. What sense does it make to recirculate combustion products through your motor? Buy a phenolic/plastic spacer and be done with it.
Good luck,
KingFisher
Old Sep 30, 2002 | 12:04 PM
beartracks's Avatar
beartracks
EGR problem - help!
I suspect that if you laid a straight edge on the matting surface you would see some valley.
