I friend just gave me a 1989 F250 with a ZF trans and 7.3 diesel engine 4x4. Just changed the trans and tork converter fluid. Now want to change the front and rear diff fluid. Both the front and rear have a wet spot around the "cover"
Can someone recommend what fluid I should put in there and should I change the gaskets. I was intending on using full synthetic is that ok
