General Automotive Discussion
almost there
Old Aug 15, 2005 | 06:39 PM
jamesbrght's Avatar
jamesbrght
almost there
what do you guys feel about putting spray on bed liners in classic trucks?
Old Aug 15, 2005 | 06:44 PM
ddrumman2004's Avatar
ddrumman2004
Depends on if that classic truck is for show or work.
Old Aug 15, 2005 | 07:03 PM
jamesbrght's Avatar
jamesbrght
True that, unfortunately the one I am buying will be used for light work
Old Aug 15, 2005 | 07:06 PM
bumpzter's Avatar
bumpzter
I don't like spray-on bed liners. May be OK for heavy duty work, but not for show.
Old Aug 16, 2005 | 01:40 PM
rebocardo's Avatar
rebocardo
If it is a classic truck being used for light work, I would make the bed fairly perfect, spray in a colored liner, then drop in a drop in liner to protect the spray in liner and to prevent rips and tears. You should put weep/drainage holes at the front of the bed so water under the liner can escape.
Old Sep 2, 2005 | 10:48 AM
cttrucker's Avatar
cttrucker
Spray-in
Line-X dealer:
Maybe you should consider a spray-in that meets your needs. Line-X offers a liner that will hold up to commercial use, looks good, and can now be color coded with a Dupont Kevlar paint for premium looks.
Good Luck!
