Has anyone removed their dash mount pull out drink holder. Looking to find out how to do it. Removed the two face screws but there definately appears to be something else holding it in. Any help would be great.
Chris
Not sure if it is the same as the earlier models, but give it a try:
Remove the ashtray. There should be 4 screws holding the ashtray frame to the dash. Remove them and the frame. If you look up, with the cup holder in the open position, you should see two screws. Remove them and the cup holder should slide out.
