1978 - 1996 Big Bronco
New Brake Line Procedure
Old Aug 15, 2005 | 04:52 PM
ctch88's Avatar
ctch88
I replaced the brake line that runs from the HCU to another line (connects directly above fuel filter). Do I need to bleed the HCV, or just at the wheels. Would I bleed the HCV similarly as at the wheels? This is my first time messing with the brakes, so any related advice is also appreciated.
The Bronco is a '90 351, so it only has RABs 1.
Old Aug 16, 2005 | 08:29 AM
ctch88's Avatar
ctch88
Follow up:
I bleed the rear wheels, then moved up to the HCV. The front driver side bleeder I couldn't get out using a flare nut wrench or a pipe wrench. And the brakes are only a year old...last time I go to car-x..anyway... On the driver side, I was able to get the bleeder loose, but no air came out.
New Question:
Am I correct in thinking that the hose I replaced is not in circut with the front brakes? If so can I not worry about bleeding the front driver side? I tested the Bronco in the back yard last night, and she braked well, I didn't notice any difference in braking performance, but then again, it's been 3 months since I last drove her, so I'm a little rusty on how she should feel.
Old Aug 17, 2005 | 03:38 PM
ovalholic's Avatar
ovalholic
As long as you didn't run the master dry while driving or bleeding, you should be all set on the front.
Old Aug 17, 2005 | 09:00 PM
psychlopath's Avatar
psychlopath
Even if you ran the master cylinder dry, you'd only have to worry about whatever end ran dry. The systems are isolated from eachother for safety reasons.
Old Aug 17, 2005 | 10:14 PM
ctch88's Avatar
ctch88
Thanks guys, good to know.
Hobdy
36
Apr 22, 2019 04:44 PM
Chevmn56
Mar 26, 2017 01:32 PM
1996_5.8
18
Mar 9, 2017 05:04 AM
cjben
Oct 20, 2015 01:55 PM
Battman76
23
Oct 21, 2006 07:02 PM
