8 inch front lift do i need to lengthen front driveshaft
Old 08-15-2005, 01:59 PM
mtgrzlyman's Avatar
mtgrzlyman
mtgrzlyman is offline
got a 6 inch now but the 37s rub so talked to bds and they will work me out a deal on a set of 8 inch fronts, rear is already 2 inches higher than front. will i have to lengthen front drive shaft?
Old 08-15-2005, 08:57 PM
soutthpaw's Avatar
soutthpaw
soutthpaw is offline
yes you will or at least should. also it is recommended to have drop steering linkage and may need to drop carrier bearing too as well as needing longer brake lines and sway bar drops and track bar or TTB brackets to keep the geometry correct.
Old 08-15-2005, 09:03 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
PowerstrokeJunkie is offline
yes on top of that i would recommend new brake lines, new drop pitman arm, adjustable extended drag link. a dual steering stabilizer would help dampen steering.
Old 08-15-2005, 10:27 PM
El Gato's Avatar
El Gato
El Gato is offline
Ditto, ditto, and ditto. However, you just need to trim a little off the back portion of you inner fender well, drill a couple holes in it, and pull it back with heavy duty zip ties and your rubbing issues are non-existent.
Old 08-16-2005, 02:59 AM
sean23johnson's Avatar
sean23johnson
sean23johnson is offline
i fully agree, if you deside to go with the 8in springs i think that you will find that the 37's look a little too small. i would trim the inner fender and leave the 6in lift, just my 2 cents.
Old 08-16-2005, 10:06 AM
mtgrzlyman's Avatar
mtgrzlyman
el gato ive done the trimming and it really helped, ive also cut a little of the fender away just to make sure. on the 8 inch kit according to bds all the hardware is the same from the 6 inch just different springs. i dont want to get into replaceing everything on my current lift though if thats the case.
Old 08-16-2005, 05:29 PM
El Gato's Avatar
El Gato
El Gato is offline
Sean, that is what I ment to say. Stay w/6".
Old 08-16-2005, 05:45 PM
mtgrzlyman's Avatar
mtgrzlyman
el gato do you have a pict of your truck, im thinking i didnt get a full 6 inches of lift maybe????
Old 08-16-2005, 10:23 PM
El Gato's Avatar
El Gato
El Gato is offline
Instant message me and I will send you a pic from my email account.
bernette
1947 and Older Ford Trucks
11-29-2015 07:46 PM
Vince79vette
03-19-2015 06:10 PM
rangerottis
Garage & Workshop
05-12-2014 01:27 PM
79Ranger250
04-12-2014 07:58 AM
P38fighter
02-22-2014 09:52 PM
Quick Reply: 8 inch front lift do i need to lengthen front driveshaft
