need help!!!!!!
Old Aug 14, 2005 | 08:59 PM
use4low's Avatar
use4low
need help!!!!!!
Being a guy it's hard to admit but I need your help. I recently sent my rear differential(8.8) southbound through(yes through)the rear cover destroying everything but the housing. In the process the truck stopped dead at 45mph. A horrifying sound none the less. Upon inspection I noticed the drivers side radius arm bent 90 degrees up into the front driveshaft. No big deal right, replace the radius arm. Problem is I can't seem to find(that isn't entirely true because there are 15 trucks in local boneyards) a replacement radius arm. The junkyards tell me they don't have any even if they do. I'm not allowed to pick my own parts up here due to insurance regs. If anybody has a stock radius arm for a 95 f150 or know where I can get one, pease let me know Thanks
Old Aug 14, 2005 | 10:25 PM
Jack01's Avatar
Jack01
internet search for the arm try national trucks in california huge wrecking co..not at home so i can not give you the number...fordparts .com or you can check with a few mags that have kits for our trucks such as jegs or the source
Old Aug 15, 2005 | 06:24 PM
use4low's Avatar
use4low
I can get extended radius arms from skyjacker and other companies but its not in the budget right know. Same with going through a dealer. I was hoping to find one second hand. Thanks
Old Aug 16, 2005 | 09:01 PM
use4low's Avatar
use4low
Ordered a new one from ford today $110 shipped. $115 from a salvage yard in Oregan
