boost problem
Old Aug 14, 2005 | 08:38 PM
kens crewcab's Avatar
kens crewcab
boost problem
i have 96 crew cab when i get 15lbs boost it stops like some thing is holding back, almost like a govener. know its a new motor[used with about 90,000 miles] i have a 3in down pipe with 4in open exhaust a open air cleaner, the ebpv has been gutted , it has my turbo ,fuel pump,highpressure pump, a new fuel filter, the only difference is the exhause tube that gos to the exhause back pressure sensor was clog i opened it up before all this [ new motor] i was getting 21lbs of boost. any ideas
Old Aug 14, 2005 | 10:02 PM
444dieselrod's Avatar
444dieselrod
What does the pyro do??? I don't see it defueling at only 15 psi. maybe a bad map sensor but I highly doubt it, mine wouldn't go over 7 psi when the map died.
Aren't you running that thing on veggy too??? or was that some one else??
Diesel Rod
Old Aug 15, 2005 | 04:54 PM
kens crewcab
i don't have a pyro i know i should just never got a gauge, yes that was me with the feg oil but haven't ran it since new motor just working the bugs out than i will run oil, thats what it fells like somethings stopping the truck , it fells like it wants to keep going but it holding back, i do have a map senser i'll try that
BURNSTOUGHFORD
Jul 19, 2012 05:57 AM
Gmangh15
Feb 15, 2012 10:27 PM
89ford73
52
Nov 14, 2011 08:42 AM
99powerstrokeSD
15
Jul 6, 2007 10:59 AM
james northen
Nov 19, 2004 10:13 AM
