engine swap
Old Nov 19, 2004 | 09:04 AM
james northen's Avatar
james northen
engine swap
I have a 65 f-100 2wd that has a 302 mounted using the motor mount towers. It also has power steering using the ford box. Now if I wanted to slip in a 351w will I use the same motor mount towers and will the stock 351w exhause manifold clear the steering box. Forgot to say that it is also a 3 speed on the column so will my bell housing bolt up to the 351w. The 302 in it now has the standard exhause manifolds. Thanks james northen
Old Nov 19, 2004 | 10:13 AM
312's Avatar
312
its a drop in.
james northen
Jul 30, 2006 07:55 PM
james northen
23
Dec 2, 2004 03:05 PM
james northen
Dec 19, 2003 09:08 AM
4xfordman
1978 - 1996 Big Bronco
Nov 26, 2001 11:24 PM
