Sponsored by: Auxito
pcv valve
Old Aug 14, 2005 | 03:16 PM
piperig78's Avatar
piperig78
pcv valve
hey guys i have a 2001 f150 with the 5.4 with 40,000 miles on it. I changed my oil and put in a new pcv valve. After putting it in my truck idled alot lower and when put in gear it would drop below 500 rpms, so i took it out and put the old one back in and it was back to normal. anyone know what would have caused this i am wonderig why a new one would do this? help would be greatly appreciated, thanks.
Old Aug 14, 2005 | 06:04 PM
steve(ill)'s Avatar
steve(ill)
PVC is positive crankcase ventilation. what this is, is basically a hose that connects the motor insides ( valve cover) to the intake manifold. the intake sucks the oil fumes out of the motor and allows room for fresh air to enter. the amount of vacuum you have is determined by the pvc valve which is a ball and seat ---backflow preventer. baasically a "big" pvc valve would act like a vacuum leak as seen by the intake manifold. you might have a slightly different pvc valve than original. see that is it made for your truck and not a general fit type.
Old Aug 16, 2005 | 06:03 PM
piperig78's Avatar
piperig78
it is the right one for the truck thats why i didnt get why it didnt fit. ANy more suggestions anyone?
Old Aug 16, 2005 | 06:04 PM
piperig78's Avatar
piperig78
i ment to say why it didnt work? and why my rpms dropped?
Old Aug 16, 2005 | 06:17 PM
LxMan1's Avatar
LxMan1
It is probably allowing more air in than the PCM is used to and is not getting the same amount thru the MAF. You might try unhooking the battery for about 30 min. to reset the PCM. It may be ok after that.
