1978 - 1996 Big Bronco
Hot Headers
Old Aug 14, 2005 | 02:45 PM
ctch88's Avatar
ctch88
Question Hot Headers
To catch you all up before I ask this question: I just installed a reman. motor into my '90 351. Upon starting it the first time, my new bassani headers started glowing, but the water temp. was normal (started cold and slowly climbed to halfway between the "C" for cold and the "N" in normal). The heat melted a vacuum hose which I replaced today. It's the peach colored one that runs to the bottom of the regulator looking thing above the passenger side headers. I think it's just a worthless piece of the emissions system.
I started the engine again today, and again the vacuum tube melted even after I wrapped it in loom, and tied it as far away as possible from the headers. Finally the question: have those of you with bassani headers had this problem of producing so much heat that your melting stuff and changing the appearance of the HTC on the headers?
Thanks in advance, I'm really frustrated about this.
Old Aug 14, 2005 | 03:11 PM
freak98's Avatar
freak98
Sound's like your too retarded on your timing or too lean.
Old Aug 14, 2005 | 03:33 PM
ctch88's Avatar
ctch88
I've read that some people have bumbed up their timing to 10 or 12*, would that help here?
Old Aug 14, 2005 | 05:14 PM
freak98's Avatar
freak98
Try and advance the timing the try to richen it up.
Old Aug 14, 2005 | 07:09 PM
ctch88's Avatar
ctch88
Alright, I tweaked the timing a bit, and it seems were running very well. Everything is stable and it idles at about 850 RPM. Thanks to all.
